Getting "Error Logging In" when creating a ticket
lread1
Hiya,
I created a community account so I could submit I ticket, but when I try to log in with my community account username and password on the "Submit a ticket" page, I get "Error Logging In".
My community account username and password works to login here (hey, I'm posting this message, right?).
If I open my browser web dev tools, I see a 500 Internal Server Error for "lithium-login".
12 REPLIES 12
lread1
Thanks @frenchonion, that answer will help folks with a Public Mobile account, but I don't have one.
frenchonion
I had a similar problem too, it gave that error after I put in the My Community username and password. I even tried the My Account login but it didn't work either. So I ended up doing the second option they give which is to enter in the account PIN and name. That worked and I got a reply to my ticket afterwards.
@Patchio  please open ticket via direct message, provide them your order number
lread1
Much thanks for this tip @Patchio, I have sent a PM to CS_Agent.
Patchio
@lread1
Yes, in this case you can only private message the CS_Agent account to return the phone, because you actually need to be a PM customer in order to complete the standard ticketing process. It requires the Community AND Self-Serve My Account login credentials, which you don’t have.
Patchio
@lread1
Private messaging is the only other method of submitting a ticket when you are unable to log in to the ticketing system with your credentials.
This is not a problem on your end. This is an issue on PM’s side of things. I have experienced this issue multiple times and had to private message the CS_Agent account to get a ticket started.
lread1
Thanks Patchio, I'm not a Public Mobile service customer, so i don't have all that info.
I just bought a phone from Public Mobile, and I think I want to return it.
But I'll give that link a shot anyway, thanks!
lread1
If I could submit a ticket for not being able to log into the ticket system I would, but, well, that's not possible.
Patchio
@lread1
If you are unable to submit a ticket through the SIMon chatbot, please send a Private Message to the CS_Agent account using the link below to get a ticket started:
With this method, you will need to check your private message inbox (i.e., see the envelope icon at the upper right corner of the Community website).
Be prepared to verify and confirm ownership of the account by answering multiple questions, such as:
  • Your first and last name
  • Public Mobile Phone Number
  • Pin number
You may need to answer supplemental questions if you are unable to provide your PIN number.
lread1
Oh, I don't know how these forums work, I replied to you Meow, when I should have added to the topic here.
(I don't see my reply to you so I guess it was private?)
Edit: oh wait, replies show newest to oldest, there it is!
lread1
Thanks for the tips.
I have tried all of the above from Chrome and Firefox on my Mac laptop and my Linux desktop.
No luck for me.
The 500 error strongly implies something unexpected is broken on the server side.
Hopefully some public mobile support staff are reading this forum and can check it out.
Meow
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
