08-19-2019 11:44 PM - edited 01-05-2022 06:30 AM
Getting a "Not registered on network error" now, halfway through the day after making calls earlier in the day. Nothing has been changed.
Network mode is GSM/HSPA/LTE (auto connect)
Access Point Name is Public Mobile 2 (sp.mb.com)
Network Operator is Telus
When I scan for all available networks, I can see
Public Mobile
EXT
Bell
Freedom
AT&T
313100
Choosing Public Mobile or Select automatically just kept returning me to Telus. Just now as I am typing this, I touched 313100 by mistake and of course after a long interval it informed me that the SIM was not allowed on that network. I then hit Select automatically once more and this time it came up as Public Mobile. So I tried a phone call and it worked.
Any idea what is going on?
08-21-2019 01:53 PM
Thanks for the suggestion, using airplane mode sounds like a good trick to try whenever we have connection problems.
08-19-2019 11:51 PM
If its now working it may have just been your phone was having issues connecting to a proper tower.
If this happens enable(turnon) airplane mode wait 15 seconds then turn it off and that usually does the trick.
Rebooting the phone too sometimes helps.
We get similar things here.
08-19-2019 11:48 PM - edited 08-19-2019 11:50 PM
08-19-2019 11:47 PM
@CaptainSnorkel wrote:Getting a "Not registered on network error" now, halfway through the day after making calls earlier in the day. Nothing has been changed.
Public Mobile
EXT
Bell
Freedom
AT&T
313100
Sounds like you might have stumbled upon a nice resolution. Not sure why it would have stopped on you in the first place though.
