04-09-2023 11:27 AM
Hello Folks,
I hope you're doing well. I would like get payment information, specifically the amount of GST/HST I paid for the 2022 year. Could I please speak with someone to get this information? Thanks and take care.
04-09-2023 11:34 AM - edited 04-09-2023 11:37 AM
You can also go into your Payment tab within self-serve and save to PDF a file from within the payment tab.
Give it a go - it may serve your needs.
( Adding: I just tried it. While it does generate an 'invoice-type' document, it fails to display the applicable taxes and just shows net amounts. May not be useful for your needs, @BootlegSaint )
04-09-2023 11:29 AM
yes, you get get invoices with tax info, but you need to have PM agent to prepare you the invoices
Please submit a ticket with CS agent and they will prepare for you
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
