Friend referral
JcCameron
About 5 hours ago I signed up a friend and entered my referral code in the appropriate box during sign up. I didn't get any notifications about it working, neither did my friend although the account was successful and she is now using her plan. How do I confirm? @CS_Agent
Pey82ton2
I’ve done this twice now where I’ve entered my code and forgot to hit button beside where you enter it and just go to bottom of page and hit save/next. It didn’t load my code. Just contact CS_Agent  and they will fix it for you after getting the information they need.
Satanica
It can sometimes take 72 hours, possibly more if there is a holiday or a weekend
@JcCameron
Your friend would have got a text “Cha-Ching! You just added to your RAF reward-way to go!
You will get your $10 credit in your account in 72 hours.
@JcCameron your friend will see the $10 in My Account within. 72 hours.
@JcCameron  If you entered your referral code correctly for your friend you should see the $1 or 1piont depending what rewards your on and they should see the $10 credit with in 72hours
add typo
