Free data missing
baldy1
Why is my free data not showing on my account any more?
12 REPLIES 12
azeemhaq
Check the usage, normally when the whole data is consumed, you dont see any available data in the balance bucket.
To get instant data, two quick options you have. Either get data as add-on, or go for the change of plan. pay the due amount of your selected option and you are good to go...
Thank you
@baldy1 wrote:
Sounds reasonable, although they never said it would be on a one time declining scale. Nonetheless thanks for your help
I haven't heard of a long time customer awarding of data. Not saying it didn't happen. Usually data is either in your plan and also added as autopay bonus to plan data. That data gets refreshed each paid term. Unused portions are not banked.
Then there are add-ons which can be added by way of you purchasing it or by being gifted to you or by way of promo. These will stay on your account until consumed.
Then there are promo buckets of data which could get refreshed each paid term for a limited time or act like add-ons.
But to not be seeing a particular bucket of data in your overview page means that you've used it.
baldy1
baldy1
Thank you.
popping
@baldy1 wrote:
Why is my free data not showing up on my account?  Who do I contact from Public to inquire?
When you used all your add-on data, it will not be shown on your overview page.
The following is from ny overview page.  I have used 0.177 MB of on 1024MB free data.
It will not be shown if I use all 1024MB free data.  The minutes add-on will do the same.
  • Data & Add-OnsAmount Used
    $0 Free Holiday Giveaway: 1GB Add-on
    0.177  /  1024 MB
    $0 Free Holiday Giveaway: 400min INTL Long Distance (incl CA & US)
    3  /  400 MIN
    50 International Outgoing Texts and Unlimited Incoming Texts
    10  /  50 Unit
    500 min Canada-Wide Long Distance
    0  /  500 MIN
No need to contact PM because you will get the same answer from moderator.
@baldy1
There are 2 ways to contact the Moderator Team:
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
Welcome to the community.
@baldy1 you may have used it. and it doesn't renew after it had been used sorry
baldy1
They awarded it to me for my long time service and never mentioned it as temporary. Should have been added to my account as permanent. How can I reach Public to inquire?
baldy1
gblackma
@baldy1  normally when its not there, you have used it all. Welcome to the community.  Stay safe.
ShawnC13
If it was showing previously and now it isn't that means you have used up the data.  Do you feel that you didn't use up the additional data?
baldy1
