Free data addon
12-04-2019 11:59 PM - edited 01-05-2022 08:20 AM
12-05-2019 09:30 AM - edited 12-05-2019 09:31 AM
Sounds as though they are getting it sorted out. Give it some more time.
Someone likely had to put in some OT last night!
AE_Collector
12-05-2019 09:20 AM
OP Update
The previous fee data appeared back, but the holiday free data is still showing use up. I guess the holiday free data addon replace the regular location. Hope it can be solved soon.
12-05-2019 12:39 AM
What plan are you on and what is the status of your regular plan data? Is it normal?
AE_Collector
12-05-2019 12:10 AM
@yezijie001 wrote:I purchased zero dollar addon today. However, my 1gb free data got on august or September disappeared and the free data usage became 800mb. How come about it
Keep watching in the Announcement section as it sounds like yours is a commonly reported problem today. I'm sure they'll make your data proper once the issue is sorted out.
12-05-2019 12:02 AM
You are another customer with similar issue of data running out faster when you added the promo data add on. Hopefully, PM will have a fix for this soon.
