09-05-2022 08:43 PM - last edited on 09-05-2022 10:09 PM by computergeek541
Hello Moderator,
i,m looking to buy Free SIM card. Can you please help? Thanks
09-05-2022 10:11 PM
@Arpit09 wrote:Looking for free sim code pls
Sorry, but Public Mobile does not provide free SIM cards.
09-05-2022 09:34 PM
@Arpit09 wrote:Hello Moderator,
Buy and Free in your sentence is confusing @Arpit09
Did you purchase a certified phone from public mobile and not receive a sim with it, which should come free? If so, tell a CSA about it so they send you one you should have received.
09-05-2022 08:57 PM - edited 09-05-2022 08:58 PM
Hi @Arpit09 the friend referral code does cover the cost of a sim card to make it a free sim card.
Sent
Add: oh, I might be late 🙂
09-05-2022 08:53 PM
@Arpit09 hi I sent you one check your community envelope top right corner
09-05-2022 08:50 PM
@Arpit09 you meant friend referral code for activation?
I don't think you mean sim puk unlock code , right?
09-05-2022 08:46 PM
09-05-2022 08:46 PM
Go to Find TELUS Stores Near you or Koodo Stores or SIM Card from Amazon to buy it SIM card.
maybe them can give a credit if you have a issue but if not have anyhting no credit to cover SIM cost.
09-05-2022 08:45 PM - edited 09-05-2022 08:46 PM
@Arpit09 buy ot free??
you can buy a sim card from yiur local Telus or Koodo store for $10
Also, you can also get it from Amazon , it ships fast with Prime membership
https://www.amazon.ca/Public-Mobile-Card-Unlocked-Phones/dp/B07R6P5KBB
