Forgot username and email
eunak
Hi, I forgot my email and username, and haven't been able to get it back. I submitted a ticket, but it's referring to changing my password, not my email on file.
2 REPLIES 2
@eunak you could try different emails and choose the Forgot your password option to reset the password.
Are you sure a self serve account was created before, if not you can register for one here:
https://selfserve.publicmobile.ca/self-registration/
If you know for sure an account was created and no luck with the email and forgot password, then see @hTideGnow post on how to get help with CSA.
NOTE: if the account was in nonpay/suspended status for over 90 days, or you ported out the number to another provider, then you no longer have access to self serve.
HI @eunak
You have to open ticket with PM CS agent and work with them.
To open a ticket with PM CS Agent.  at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
