Forgot security question
popalfarida
My phone no longer receives calls or text messages.
My credit card expired and I need to change the expiry date.  However, the password and security question that I set 2 years ago don't work or I may have forgoten them.
What can I do to login and reset my credit card expiry date?
Thanks
12 REPLIES 12
@BophanaSince you have indicated your phone is not working, I highly recommend getting a voucher for the value of your plan (without the rewards), use 611 and add that voucher and get your phone back up and working ASAP. You might need to wait up to 48 hours for moderators to respond to you.
@Bophana wrote:
Hi,
I need to update my account information but I don't know the answer or the security question. Please help as my phone is not working right now.
Thank you
Since you don't know to the answer to your security question,  the only way to reset your password will be to contact the moderators. That can be done by clicking on this link:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Bophana
thankyou for your advice. i have done that already. hopefully i will get an answer soon.
@Bophana wrote:
Hi,
Thank you
If you have a valid payment card registered then you could use the 611 service. Or buy vouchers in store or online and also use the 611 service.
But to be able get into your online self-serve account you'll need to contact the @Moderator_Team < Click this.
Bophana
Hi,
Thank you
XionBunny
@Haocheng5 wrote:
I forgot my security question.  I need to log in  asap
Please create a new topic, so that others may help you.
Haocheng5
@Bob99 wrote:
I cannot login to my Public Mobile account - when I try to reset the password, the security question asks for my father's birthdate, but when I input it, it says it is incorrect.
You selected the question and you supplied an answer. If you can't remember how you typed it in then I guess you'll need assistance from the @Moderator_Team < Click this.
You can wait 50 minutes before another try and in incognito mode or with a different browser...if nothing help write a private message to the moderator here...https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and they will help you. Waiting time is few hours to 2 days but they work 7/7 days.
Bob99
@popalfarida
Only moderators can help with your account password.  Send a private message as described above.  However, the wait times for moderator help is 24-48 hours.  Can be even longer with all the issues going on with Public mobile recently.
If you really need your service going asap, you could buy a voucher either in store or online (via recharge.com) and input the payment voucher via dialing 611 on your phone.
popping
What can I do to login and reset my credit card expirty date?
Thanks
Send a private message to moderator for help.
