10-16-2022
12:25 PM
10-20-2022
12:15 AM
computergeek541
10-19-2022 06:03 PM
I have got the solution thanks guys.
10-16-2022 04:35 PM
So which is it...no sim? New sim? Or just no service? If no service then you have other payment options like vouchers and real time payments. Or if you know your 4 digit account pin.
Then that reactivates your account and then you can SMS all around to reset and login?
10-16-2022 04:24 PM
I've done that thank you very much. I appreciate all the input guys
10-16-2022 03:23 PM
Hi @Deeschmizz maybe open ticket wirh CS Agent and let them help reset
at : https://publicmobile.ca/chatbot.
First type Forgot logi ,
finally click the the blue link about submit a ticket
10-16-2022 03:20 PM
Its a vicious circle I'm fairly techy and I've tried every available option.
10-16-2022 12:47 PM
It doesn't look like you have active service or the sim in a phone?
Can your email be temporarily made to authorize somehow else?
10-16-2022 12:43 PM
The email connected to this account also requires 2fa which is the same phone number
10-16-2022 12:29 PM
You can change the password using SMS if you have the phone and the account sim. You can use the email option otherwise. Then yes the actual login now has 2FA which you would need active service for the SMS option - but also email.
