06-05-2019 03:01 PM - edited 01-05-2022 05:14 AM
Forgot password and security question and i need to update my credit card but cant log in somebody help!
06-06-2019 08:14 PM
Thanks I got in. Moderator helped me within 24 hours. Turned out my answer to my security question was misspelled.
06-05-2019 04:17 PM
06-05-2019 03:28 PM - edited 06-05-2019 03:29 PM
I would recommending messaging the kind folks at the Moderator_Team via this link to help with your issue.
It helps to provide a detailed description of your problem and what your resolution goals are so they can best assist. If you are having troubles contacting the Moderator_Team, refer to the following knowledge base link.
Moderator hours are as follows and generally you can expect a response within 1 hour or up to 48 hours depending on volumes...
Best of luck!
@Yeah00 if you're pressed for time (as your due date for your bill is coming up) you could purchase a voucher and load your account over the phone. It could be less stressfull in case you're worried your service gets cut. The moderators might not be able to answer right away.
06-05-2019 03:03 PM - edited 06-05-2019 03:09 PM
Click on the link below to send a message to a Moderator to help you out. May take up to 48 hours for a response depending on volume.
https://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/22437
