Forgot password and cancel account
Victoriadalfons
I changed my visa so my account was suspended. I cannot log in to public mobile because I forgot the password and security question answers so was logged out.
I found a better plan somewhere else but want my number transferred but I can’t do so unless I log in. Please help!!!!
Victoriadalfons
This is the ticket I submitted
Victoriadalfons
This is the ticket I submitted.
gblackma
@Victoriadalfons unless you are porting to Telus or Koodo.  Your plan must be active to port your number out. I would suggest contacting the moderators and ask them to give you atemporary password to your self service account,  reactivating the plan on the $15 plan and then porting your number out. There are 2 ways to contact the Moderator Team:
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
gpixel
@Victoriadalfons
(use the chat bubble options, then click "submit a ticket, click me" option)
make sure to check your inbox(top right corner envelope icon) periodically, for a response
will13am
@Victoriadalfons , you can contact the moderator team by clicking the ? and follow the prompts to initiate a support ticket. Sorry to see you go.
