Forgot my password and security question answer
Thomas999
i can't access my self serve, because i seem to have forgotten my password and the answer to my security question. I need help , Can someone please assist in getting my account back so that i can Access my account online Please and Thanks.
@StephenWeadick wrote:
System does not seem to accept UserName and Password. I have reregistwered againReceived text from Public Mobile stating that my credit card will expire end of Sep 2021. It has been re-issued with expiration of 09/24. I am on auto pay.
@StephenWeadick
try to do Forgot your password click Here link , and enter your email address,
and if still not fix it you Have To Submit a Ticket To Contact Customer Support Agent by  ,
Explain your issue to they can solve your issue, they are nice service Team the will help you 100%. and they will Reset for you,
Here’s how to contact Customer Support Agent by CS_Agent,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Service by CS_Agent. Click Here link to get started.
  • or you can send a private message to Customer Service by CS_Agent, by Click Here link
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
         Good Luck..
 @StephenWeadick : See the post just above yours.
StephenWeadick
@Thomas999
         Good Luck...
You will need to go to https://widget.telus.tiia.ai/publicmobile/publicmobile.html .  After going there, type in "forgot security question answer". If at all possible, the chatbot (SIMon) should be used for opening this ticket.  This is because sending a message directly to a customer support agent will get your request assigned a lower priority.  In addition, the the password reset option in the ticketing system will gather all necessary information for you and will reduce the amount of back-and-forth required to get your password reset.
t_p
You need to contact CS:
Private Messages - Community (publicmobile.ca)
They will ask for more info to authenticate and reset your password.
