01-07-2022 08:26 PM - edited 01-07-2022 08:34 PM
Hello,
I can’t remember my email/username for one of my accounts and need to update my visa expiry date.
My Account
01-08-2022 12:38 AM
01-07-2022 10:30 PM
@Graychrisg wrote:Hello,
Is your renewal tonight? You can buy a voucher from stores and use 611 to pay to your account.
01-07-2022 08:34 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent
- you can send a private message to Customer Support Agent by Click Here link,
- please include in your message,
- phone number,
- Email address,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
- During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
- Monday to Sunday: 6 AM to 10 PM EST
- Note: Public Mobile No Support by phone call or Email.. only by CS_Agent, private message..
Good Luck...
01-07-2022 08:29 PM - edited 01-07-2022 08:30 PM
Hi, you can try to reset with Forgot Password link . Try to put in the correct email address then answer the security question.
if not work, open ticket with PM support using chatbot. click on the Bubble on the lower right or directly at : https://publicmobile.ca/chatbot.
Follow these these to get to ticket open page quicker:
type: Forgot log in information
Click "Contact Us"
Click "Click here to submit a ticket"
01-07-2022 08:28 PM - edited 01-07-2022 08:29 PM
@Graychrisg - do you have email you can try, then use the Forgot your password option?
If not, contact CSA for help.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Customer Support Agents (CSA)
EDIT: I forgot to ask...did you ever create a Self Serve account? If not you can register for one here:
https://selfserve.publicmobile.ca/self-registration/
FYI - please remove any personal information from your thread, this is a public forum. thx
