07-27-2021 07:33 PM - edited 01-06-2022 02:55 AM
My wife forget log in information, both email address and pin, how can she get her log in information? thanks
07-27-2021 11:04 PM
@ben2018 wrote:thanks, that a robot
you can get to ticket opening quicker by typing this:
type: Fogot log in information
Click "Contact Us"
Click "Click her to submit a ticket"
you will then got to another page to open ticket.
There, you will be prompted to enter COMMUNITY Login (NOT My Account/Self-Serve) to validate your identity,
07-27-2021 11:00 PM - edited 07-27-2021 11:03 PM
Yes, the above chatbot link does take you to a "robot", but it enables you to be able to contact the moderators.
07-27-2021 07:39 PM
07-27-2021 07:38 PM
07-27-2021 07:37 PM
Only one way to solve your issue , explanation to customer service by Moderator Team
and the are nice service Team the will help you 100%.
you Have To Submit a Ticket To Customer Service by Moderator Team,
Here’s how to contact customer service by Moderator Team,
Good Luck
07-27-2021 07:37 PM
@ben2018 Contacting the moderator team is the best way to get all the information after verifying. Alternatively, if you can check for a Welcome email sent by Public Mobile in all your known email accounts. Whichever contains the email is the likely email you used to activate. Once you know the email address, you can reset the password using the forgot password tool.
07-27-2021 07:35 PM - edited 07-27-2021 10:59 PM
@ben2018 wrote:My wife forget log in information, both email address and pin, how can she get her log in information? thanks
You'll need to open a ticket at https://widget.telus.tiia.ai/publicmobile/publicmobile.html
07-27-2021 07:35 PM
Contact a moderator (Public Mobile representative) for assistance:
(second option below is easiest to submit a ticket)
