Forgot ID
sikita
Hello,
I forgot my eversafe ID, could you please send it back to me? My electronic adress is xxxxxxxxxxxxxxxx@xxxxxxxxxxxx
2 REPLIES 2
HI @sikita
try the Forgot login link and PM will send an email to the correct email address.  Of course, you will have to check all your mailbox (and check the spam folder) to see if you get that
if you cannot find it still, then support agent can help.   Please message them directly here:
Sorry, but Public Mobile does not provide customer service over e-mail. As for your EverSafe login, it is your e-mail address (whichever one you used, and it could be the same one that you just mentioned).
