For help
Phi-Khanh76
I can not sign in my account on website. Pls advise. Tks
Khanh (Mr.)
tabi159w
The self-serve portal is slow, so be patient. The server may just be over loaded.
GinYVR
@Phi-Khanh76Can you give us a screen capture or the exact phrasing of the error message? We are all customers here, so we can't see what you are doing.
PMFanatic
I would recommending messaging the kind folks at the Moderator_Team via this link to investigate your account and to provide some additional insight into your issue.
It helps to provide a detailed description of your problem and what your resolution goals are so they can best assist. If you are having troubles contacting the Moderator_Team, refer to the following knowledge base link.
Moderator hours are as follows and generally you can expect a response within 1 hour or up to 48 hours depending on volumes...
  • Weekdays 8:00am - Midnight (Eastern time)
  • Weekends: 8:00am - 10:00pm (Eastern time)
Best of luck!
Triguy
You could try the forgot password link.  Also try logging in using a different browser and incongnito mode.  Try also clearing your cache.   If you still have problems then try contacting a moderator.
Moderator can be reached at
geopublic
Khanh (Mr.)
@Phi-Khanh76  Did you just activate your account?
