09-12-2023 04:08 AM
Anyone else notice that this filter is gone in Self-Serve, to filter by Debit or Credit? There is only the ability to filter by date range.
I need to filter for just the Debits.
09-12-2023 02:21 PM
then look like there is really not much customer can do until PM fixes the issue
09-12-2023 01:48 PM
Thanks for the workaround.Unfortunately, that is not useful for my purposes, as I need to isolate the data of interest in the absence of all the rest. There are multiple reasons.
Plus the current format makes the report MANY PAGES long, when by filtering I could make it a page or two.
09-12-2023 07:45 AM
Yes, the option is not there any more.
A workaround I can think of is to download it in PDF, then you can use text search to look for specific word so it can highlight all those debits you are looking for.
