Failed text Messages
Dagbe3
My text messages are not going through. What should I do?
@Dagbe3  .try resetting network settings . Also is it possible to try the SIM card in another  phone to test
dust2dust
If iphone then go to settings, general, about and see if anything wants to download. And do a full power off restart of the phone anyway.
@Dagbe3
Android or iPhone?
did it ever work on Public mobile network before? or you just joined and it never works?
if you are using Android, try clear app cache first.  If fails try install Google Message and set it as default and use it to send and receive, see if it helps
if that does not work or you are using iPhone, try click Reset All networks and see if it helps
