Failed SIM activation
dooba7
I am speaking on behalf of a new Public mobile member.
I was trying to activate my SIM transferring from Koodoo.
I was on 5G instead of wifi however, activation failed and i could not restart the process.
I did not put the Public SIM card before the transfer process.
How do i try to start activation again?
@dooba7
at this port , it is likely a problem with activation and not a problem with porting, not yet.
Please submit ticket with PM agent as advised above
dooba7
We waited 15 mins we are still stuck in step 6
dooba7
it is post-paid
mitchnet12
@dooba7  Did you get a text message from Koodo asking a question about porting, and replied yes? If not, re-install the Koodo SIM without delay, and reply to the text message once it comes in. @Handy1 makes a good point about the Koodo plan that you're on.
HI @dooba7
did you got the Activation failure at Step 6? Logoff the app, and wait 15 minutes first.  Try to login again with email address and password and see if the app can send you the code via email and confirm full access from there
If issues persists, please open ticket with PM support
@dooba7  Is the Koodo account pre paid like public mobile or post paid ? If pre paid you need to create account on the app not website . Only app will work and pick a temp public mobile phone number and you have to get support to transfer the number for you
send a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
