F1 login error and data plan not working
yr_
I just installed my Sim yesterday and my data is still not working. I'm not receiving all my calls and texts. every time I try logging in it gives me a Forbidden F1 message. I can't find how to send a ticket.
1 REPLY 1
HI @yr_
can you make outbound calls?  is the sim showing connected to the network? physical sim or esim?
since you cannot login as well, best to check with CS agent.  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
