7 hours ago
- last edited
53m ago
computergeek541
6 hours ago
I just received this from PM...
"Thanks for reporting this! I have checked and there is a general outage in the western area so right now our support team is working to resolve this asap. We apologie for the situation and we`ll let you know as soon as we have an update!"
6 hours ago
It's not just your issue. I'm having the same problem and so is my husband, who is currently at work in a different city.
6 hours ago
I have. My husband also can't call out so it's not just a "me" issue.
7 hours ago
open ticket with PM as well so they are aware
7 hours ago
Mine is doing the same this morning. Must be some kind of outage.
7 hours ago
@Kittycat3 wrote:Yes I tried several. Some local, some long distance. I can receive call, but I am not able to call out. It says call ended before it dials out
What about texting? data?
Might be an outage in your area:
7 hours ago
better to try your sim in another phone if possible
and of course, ask PM to check. They might be able to reset the service on the system and it would fix it
7 hours ago
7 hours ago
Try also calling with a 1 in front of the 10 digits , or calling without if you have been calling with the 1
and you tried calling different numbers, right?
7 hours ago
This is recent. I have rebooted my phone. I can re everything calls but cannot dial ot. It says call ended as soon as I dial out
7 hours ago
but can you receive calls? data work?
try reboot the phone and try reset all networks and try your sim card in another phone
and you have that problem everywhere? or just some particular places like your home?
if you cannot make it work after trying above, you need to ask PM. You can open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
7 hours ago
@Kittycat3 , this a recent issue or persistent? Are you getting decent signal strength during the call? Does it happen everywhere or just certain locations? Have you tried rebooting your phone?
