Esim
Pete7383
I originally got my number on my android through eSIM on my android now I need to switch my android to my iPhone, which is also eSIM compatible so I basically just need to buy an eSIM for my iPhone so I can switch my android to my iPhone
Moved:
@Pete7383
For eSIM with new phone, you have to re-buy a new one for $5.
Yes,  while eSIM is "cool", there are disadvantages as well.  For eSIM, if you have a new phone, or if you ever wipe your phone, you will have to re-buy a new eSIM again.   There is no such problem with Physical sim card.
To rebuy new eSIM, First, download the app on your new phone, click   or    at the bottom left to bring up the menu and go to Subscription & Add-on page, scroll down to the bottom and click Shop SIM Card Now.  You can buy and install eSIM from there
Chalupa_Batman
Hello @Pete7383
Sadly you will have to purchase a whole new eSIM if you chose to go that route. Hence the reason I always recommend a physical SIM card.
