Esim
MinnieMouse67
I purchased a subscription today. When I tried to set up my phone.    It told me that my phone was not esim compatible.    So they told me to get a refund
@MinnieMouse67 wrote:
My phone is an iPhone 8 Apple
they are you who ever sent a message telling me my phone was not compatible
@MinnieMouse67   Yes, in this case, going back physical sim is the way to go.  You can get one quickly from a Telus/Koodo/Mobile Klinick store (call for availability first), or via Amazon for quicker shipping time
The 8 does not have esim capability. You can only use a physical sim.
https://support.apple.com/kb/SP767?locale=en_CA
https://support.apple.com/kb/SP767?locale=en_US
MinnieMouse67
@MinnieMouse67
what phone do you have?
you want to change to physical sim instead?
or with eSIM, how far you got to?
Did you get to the eSIM installation step?   Either the app will ask for your permission to do it for you automatically, or you will get a QR code to install yourself.
If you missed the step, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step),  try to reboot your phone once.
If it still does not connect and if you have any active sim on the phone , disable them (eSIM/Physica sim) or remove the physical sim.  Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after)
if it still does not work, please open ticket with PM support
@MinnieMouse67 please
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
hairbag1
@MinnieMouse67
what make/ model is your phone ? Who is the "they" you speak of ?
