Esim
06-18-2023 03:19 PM
06-18-2023 03:23 PM
@Sunny63 give us more info. At which stage it had issue? and are you activating on iPhone or Android?
did you check your CC to see if PM took the money yet?
if they took the money, did you get to the stage to install QR code? you got the code via email? You tried to install and failed?
Yes, you can also open ticket by direct message support here to get it sorted out:
06-18-2023 03:23 PM
06-18-2023 03:20 PM
Try rebooting device, resetting network connections, and toggling airplane mode on/off @Sunny63
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
