Esim won’t activate
Blighguy
My Esim won’t activate   Any ideas why?
12 REPLIES 12
YHHH
i got: Unable to activate eSIM
and then i scanned the QR code sent to my email -> not working anymore
BUT I RESTARTED MY IPHONE and it worked
maple_leaf
Thanks for letting us know @Blighguy . Hope the new eSIM activates successfully.
Blighguy
Thanks for all your help. I need a new Esim code to activate and waiting on a CS agent for support.
@Blighguy wrote:
Would it work for an XR
@Blighguy , yes, it will work in iPhone XR.
Once the eSIM successfully installs you need to do the things below to activate it:
Reboot your iPhone XR.
In cellular settings make sure that “ Turn On This Line “ is selected, reset network settings & reboot.
Turn On This Line
You said the eSIM didn’t activate so you would need to send a private message to CS_Agents for help using the link that @maple_leaf provided to you.
Blighguy
Blighguy
No it’s and iPhone XR.
@Blighguy wrote:
New account. It’s now saying QR code is no longer active. How do I get a new one?  I have an iPhone 6s.
@Blighguy , my iPhone 6s isn’t eSIM compatible! Are you sure that yours is?
maple_leaf
@Blighguy , Per the eSIM FAQs link sent earlier, you have 3 tries to install the eSIM from a QR code. If 3 attempts failed, you can contact a Customer Support Agent for more assistance. I've included the link below. Also, check the eSIM Support for iPhone link sent earlier to double check that your iPhone is eSIM compatible.
Link to PM CS_Agent:
Monday to Sunday 9 AM to 10 PM EST
PhilWarner
You have to check to see if your phone is compatible with an eSIM….mine wasn’t, so I bought one for $4.99 off of amazon.ca
Blighguy
maple_leaf
Hello @Blighguy , Really not enough information to answer you. As @hairbag1 mentioned above, are you swapping a SIM for an eSIM on an existing subscription, or starting a brand new activation? What error message are you seeing? What steps were you taking? What kind of phone do you have (Android or iPhone)? I can offer the links below regarding eSIM troubleshooting, if that's helpful.
eSIM FAQs:
https://www.publicmobile.ca/en/on/get-help/articles/esim-faqs
Blog Post: eSIM/SIM Card Landscape
https://productioncommunity.publicmobile.ca/t5/The-Lounge/Blog-Post-A-Tale-of-Two-SIMs-Navigating-th...
eSIM Support for iPhone:
https://support.apple.com/en-ca/HT212780
eSIM Support for Google Pixel:
https://support.google.com/pixelphone/answer/9449293?hl=en#zippy=
eSIM Support for Samsung:
https://www.samsung.com/ca/support/mobile-devices/galaxy-esim-and-supported-network-carriers/
hairbag1
@Blighguy
new PM account or old ?
