01-18-2026
11:11 AM
01-18-2026
11:20 AM
I tried resetting the network setting with no luck.
I also find it odd when I log in to PM it tried to send a SMS to the temporary number I don't have access to anymore.
Had anyone tried an esim swap? Did it help?
01-18-2026 11:39 AM
I sent a private message and they were able to sort it out on their end. It was fixed in a day
01-18-2026 11:38 AM - edited 01-18-2026 11:42 AM
if you can login My Account using email to receive 2FA, what you need to do next is to update the phone number on EverSafe to receive the 2FA on your phone
login My Acocunt, go to Profile, Manage EverSafe ID and update the phone number there. Or you can use this direct link:
https://eversafe.id.telus.com/user/selfservemenu
For eSIM showing wrong number, try Reset network settings after you update your phone number on My Account's EverSafe
If it is still wrong, you can rebuy a new sim card for free and it will correct the phone number issue. To rebuy new eSIM for FREE, first, download the app on your new phone and login. If you have problem with receiving 2FA code, click "Didn't Receive code" or "Resend code" and choose either Send email or Send voice message
Once logged in, Click Account from the bottom, then click Purchase SIM Card and select eSIM.
Once it confirms your phone is eSIM compatible, click Pay $ and Install (the system will check and apply a $5 credit to bring the total price back to $0 at checkout), and follow the prompt to complete and purchase and install eSIM on your device
(in rare case that PM charges you for the replacement esim, you can submit a ticket with PM support and ask them for reimbursement)
https://www.publicmobile.ca/en/get-help/articles/esim-faqs
While direct eSIM to eSIM transfers are not supported, we do offer the option to transfer service from one eSIM to another by purchasing a new eSIM. If you are already using a Public Mobile eSIM, when you request a new eSIM, we automatically identify you as an existing eSIM user and waive the replacement fee, provided you meet certain conditions.
To qualify for a fee waiver when transitioning between eSIMs, you must meet the following criteria:
* The current Public Mobile eSIM must be actively installed in the device you’re transferring from.
* The eSIM must have been purchased at least 15 days prior to the new request.
01-18-2026 11:29 AM
I have been with PM for 3 weeks now. Data, calls, SMS all work using my number I ported over. So the port was completed. I do get the 2FA via e-mail.
In my profile it shows my # not the temporary. The more I'm reading the more likely I'll need to open a support ticket.
01-18-2026 11:22 AM
is that a new activation and did you request porting? was porting completed?
can you make outgoing calls and can you receiving incoming calls?
does data work?
And you mentioned you cannot receive the 2FA when logging in My Account, try this and see if you can get the 2FA via email. On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
