12-18-2023 10:50 PM
Hello my friend tried to activate on pm while registering I'm stuck at 6 and not able to activate its been 2 weeks now and also her credit card has been charged and no service
12-22-2023 11:31 AM
Thank you all for helping solution a CS agent was able to activate register my friends account.
12-19-2023 09:37 AM
Tried all options still no luck phone is not locked it's Androin she did from her phone deleted the pm app and re-download brings to activate page then next page says esim not compatible and then no other options.
How to contact to CS agent
12-18-2023 11:00 PM - edited 12-18-2023 11:03 PM
@Deepak1 wrote:Hello my friend tried to activate on pm while registering I'm stuck at 6 and not able to activate its been 2 weeks now and also her credit card has been charged and no service
@Deepak1 , to add to what @softech said, please have your friend do this on the phone that she needs it setup on using the app on that phone. If the instructions doesn’t work your friend would need to contact a CS_Agent due to I am not sure if the CS_Agent would allow you to do it on your friends behalf!
12-18-2023 10:54 PM
are you on iPhone or Android?
Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
