Esim not accepted
Kjenkins
Just started a new account for my son. His phone IS compatible with esim. While on the last step of activation the esim that was JUST PURCHASED is NOT accepted
2 REPLIES 2
Neil11
What phone does your son have? I had the same issue with my S20. Ended up having to get a physical sim. You can get one at telus/koodo store or mobile klinik. Contact a CS agent and they may credit you the cost of the sim, that's what they did for me.
@Kjenkins
there is a chance that the error was there because the Public Mobile esim is already installed and just not properly enabled
On Android:  Check your Sim Card Manager and see if a Public Mobile eSim is there.  If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there.  If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
if you don't see the Public Mobile esim there, check the Welcome email, there should be a QR code for the esim for you to scan and install manually)
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it.  If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM support using private message:
