Esim issue
LS6
iMessage and FaceTime number not working it says to remove and reinsert sim to keep using my number. I have esim how do I fix this?
thanks
2 REPLIES 2
DDM69
Try a reboot.
NDesai
@LS6 Are you able to use Data/Text/Voice currently using eSIM? Have you tried restarting your iPhone? Try doing iOS and carrier updates.
