Esim activation
Wbolton62
2 REPLIES 2
@Wbolton62 - you had an esim activation issue yesterday. Still a problem?
The 2 ways to contact the Public Mobile Customer Support Agent (CSA)_Team are below:
1 -  Normally Faster - use this link to: Get Help With Public Mobile Chatbot], OR
2 – Slower - Use this link to: Contact Public Mobile Representatives (CSA) by submitting a PRIVATE MESSAGE to start a ticket to them here: Private Message to Public Mobile Customer Support Agents (CSA)
@Wbolton62
What was the eSIM issue?
was it a problem or general question?
If you are activating eSIM and got stuck, here are some suggestions
did you get to the eSIM installation step  Either the app will ask for your permission to do it for you automatically, or you will get a QR code to install yourself.  If you missed the step, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step),  try to reboot your phone once.  i
If it still does not connect, click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after)
if it still does not work, please open ticket with PM support
