06-15-2023
08:43 PM
06-26-2023
06:04 PM
computergeek541
Hello. I am trying to activate a new esim. I was with Koodo physics sim before. Koodo has confirmed through text that porting is complete and PM representative has also confirmed. The app keeps wanting me to confirm my identity and sending a code to my phone number which is still not activated. Can anyone help me with this issue? Thank you.
06-26-2023 04:51 PM - edited 06-26-2023 04:52 PM
@Kt77789 In case you face a similar situation in the future check out Fongo for free calling in Canada while on wifi. https://www.fongo.com/
06-15-2023 09:01 PM
@Kt77789 Yes unfortunately, sorry your having this issue
06-15-2023 09:00 PM
Yes this what I’ve done. I guess I just have to wait for their reply?
06-15-2023 08:58 PM
06-15-2023 08:57 PM
But I cannot call because this is my only phone and it’s not activated.
06-15-2023 08:52 PM - edited 06-26-2023 04:53 PM
@Kt77789 Call the porting team number I send you , get status update on your port
add and quickly closes at 10pm
06-15-2023 08:50 PM
Yes I did reply yes within 90 mins. My last response from the agent through private message was that the port was complete. I am still waiting on a reply as to why it still has not activated on my phone.
06-15-2023 08:47 PM - edited 06-15-2023 08:49 PM
@Kt77789 Shoukd within minutes of activating , port can take up to two hours , if your replies YES to confirmation text .. did you do it with in the 90 min window ?there a number for live support will send it to you private message can help restart the port process
06-15-2023 08:46 PM
I have tried that. How long does it usually take to activate?
06-15-2023 08:44 PM - edited 06-15-2023 08:46 PM
