Error code
08-02-2023 05:37 PM
08-02-2023 06:15 PM
Dial *#31# to get the hidden status. My phone says restricted when hidden. It says not restricted when exposed.
08-02-2023 06:06 PM
Ok thank you, I'll try that
08-02-2023 05:59 PM
@No3 Even just taking the SIM card out and back in can force the sim to re provision itself
08-02-2023 05:57 PM
Account is active...guess I could try to find another phone.
08-02-2023 05:57 PM
I don't think my number is hidden...but I can't call out to check
08-02-2023 05:55 PM
@No3 Sorry to ask this but is your account active or on hold . Can you reset network settings or test the SIM card in another phone ?
08-02-2023 05:53 PM
And how about that hide your number setting? Or if you call someone next to you what does it show for a number on their end?
08-02-2023 05:44 PM
Yes I did. Still get error message. Added 1 plus area code to all my contacts, still get message
08-02-2023 05:41 PM
Seems to be hit and miss. Added 1 plus area code in front of all my contact numbers including local.
08-02-2023 05:40 PM
Yes I did
08-02-2023 05:39 PM
Did you try adding '1' ahead of area code even it is local call?
08-02-2023 05:39 PM
Do you hide your number to avoid caller id? Is this for all calls/numbers or just some? Is it also a problem for toll free calls?
