05-09-2023 12:45 PM
Whenever I try to reactivate my account or pay my account bill off it gives the error in the subject.
I can't get a hold of anyone with public mobile. I tried getting through help but they need so many verifications that I can't get through. I tried getting through help today and it wouldn't direct me to contact an agent.
05-09-2023 09:17 PM
The PM website is very glitchy. I have try twice when login to my account.
05-09-2023 07:23 PM - last edited on 05-19-2023 09:27 AM by Luddite
i tried a different credit cad and it worked. I dont know why the other credit card doesnt work.
[✔️ only the Shadow knows ..... Luddite]
05-09-2023 12:56 PM
If you have only tried once, you can try again using *611 to make a manual payment to reactivate your plan if you know the 4 digits PIN
If you have tried more than once, you should wait a full hour before trying again on My Account or *611
If nothing works, open ticket with PM support:
1. Please open ticket via Chatbot (requires access to My Account) using direct link: https://publicmobile.ca/chatbot.
Start by typing "Contact agent ", then click "Contact Us", then click "Other", click "Click here to submit a ticket ↗""
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
But if you need the service to resume urgnely, get a voucher from SDM/711/London Durg/Shell and load the voucher using *611 (does not require 4 digits PIN) and work with support on the credit card issue later
