Email
Makayla2
I don’t know the email attached to my accoint
Hi @Makayla2 If you don't have too many emails , try Reset Password. Put the different ones you have and check the inboxes and spame filters, one of them should work
@Makayla2
You should have got a Welcome to PM email on the email associated with your account so conduct an archive search for possible emails you used.
If all fails, you will need to have your email change by contacting a CS_Agent through SIMon Chatbot at the bottom of the page or private message on the envelope icon above.
@Makayla2
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
HALIMACS
@Makayla2
try all possible ones using the forgot password feature on the login page.
The one that sends a link to that email is your public mobile login account email.
 Adding:  another way is to search email accounts using the search words “public mobile” and the one that brings up any hits is likely also the one.
