Email
Mizk2510
I can't remember the email that I put on my account and want to know if its possible to change it with just the phone number
Please go to selfserve.publicmobile.ca and use the forgot e-mail link.  Instructions will be sent by text message with a 2FA code.  Also, an e-mail message will be sent to the e-mail account reminding of you that e-mail address was used.
hi @Mizk2510
you cannot do it yourself but support agent can help
please message them here
@Mizk2510  You need to log into you account and go profile page ”manage ever safe” and you can change it there but if you can’t  log into bet support to help you gain access and change the email
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agent
