Email
Hockeymom2024
I set up mine and my sons accounts using different email addresses. Now I can't remember what email I used for his account and I need to change billing information.
@Hockeymom2024
@Hockeymom2024
Why didn’t you mentioned the email address was hacked earlier in your first post?
@Hockeymom2024 wrote:
Just did that but now the problem is, that email was hacked, so I don't have access to it
@Hockeymom2024
Then you will need to contact customer service agent as noted earlier.  It will take a few hours to respond.  Be prepared to answer some security questions about the account.
Hockeymom2024
Dunkman
@Hockeymom2024
There is a forgot email feature:
https://eversafe.id.telus.com/user/forgotemail
Put in your son's cell number and follow prompts.....
@Hockeymom2024  Get support to help your regain access to the account
send  direct  private message to support .
send  a  private message   To CS_Agent
HI @Hockeymom2024
but you remember the password? can you login both and check?
or if you have to ask PM support agent, please message them:
