Email to SMS gateway?
SA99999
Does Public Mobile have an Email to SMS gateway and if so what is the address  format to send an SMS from an email?
SA99999
Non of those formats works. Did you actually try this yourself or are you just guessing?
 @SA99999
Yes, PM has email to sms :
To send an email to MMS with a picture (or other binary filetype) the email address format is:
Here are the different ones to use for MMS or SMS
MMS Domain:
@mms.mb.telus.com
@mms.koodomobile.com
@mms.telusmobility.com
SMS Domain:
     @msg.telusmobility.com
@msg.telus.com
@msg.koodomobile.com
fixin
@SA99999 - Go here: Messages
