09-14-2021 01:04 PM - edited 01-06-2022 03:31 AM
Hi, I purchased my sim card and plan at Walmart. But the guy there filled in the wrong email for my account. I could still log in but I am trying to change it so that I could match with my community email for rewards. What should I do? Thanks!
09-15-2021 05:57 PM
In regards to you mentioning the referral code in another thread have you received your $10 bonus referral credit in your account yet?
09-14-2021 10:45 PM
check your Community inbox (envelope icon on top right)
CS Agent will communicate with you there.
09-14-2021 01:19 PM
Thank you, I have already contacted them through submitting a ticket. Have a great day!
09-14-2021 01:18 PM
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck....
09-14-2021 01:17 PM
I already submitted a ticket, pretty easy. Thanks for replying.
09-14-2021 01:14 PM
@briannguyen92 : If you wish to earn a community reward then the email address on the self-serve and here need to match...case and all. So once you've settled your self-serve then you can do this one. Which you might already have so that's fine.
09-14-2021 01:12 PM
Yeah I'm trying to change it in my self-serve account, bc that email does not exist due to Walmart guy's typo haha. Thanks!!
09-14-2021 01:10 PM - edited 09-14-2021 04:02 PM
@briannguyen92 It is easy to change it on the Community account side. You don't need any help
If you want to change it on the My Account side, you will have to open a ticket with PM and have PM CS Agent to help to change the email address
To open a ticket with Customer Support Agent, click on the Bubble or directly at : https://publicmobile.ca/chatbot
Start with " Submit a Ticket",
then click "Contac t Us"
then click Self-Serve
then click "Click here to submit a ticket"
After ticket successfully opened, keep checking your Community inbox (envelope icon on top right) CS Agent will communicate with you there
If you have problems submitting a ticket, you can also send a private message to CS_Agents (but this can take longer):
