10-20-2022 03:50 PM
I cannot access my email to retrieve the verification code. How can I change the email on file?
10-20-2022 04:01 PM
HI @NNF Only PM CS agent can help to change your email for My Account
Can you still login with the old email address ? Please open ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Contact CS Agent,
from the list of , choose "Other"
10-20-2022 03:53 PM
you need to to contact a customer service agent for account email reset or change
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
