09-20-2023 01:29 PM
Just signed up with Public mobile and chose ESim and data is not available. Help
09-20-2023 11:31 PM
Thanks for the help. Turns out my iPhone wasn’t compatible with Esim so I had to pick up a SIM card.
09-20-2023 02:25 PM
@Viking99 wrote:Just signed up with Public mobile and chose ESim and data is not available. Help
@Viking99 , I don’t know what phone you have so my instructions may be incorrect.
In cellular settings make sure that ‘Turn On This Line’ (for iPhone ) is selected. (I am not positive where the setting is on a different phone to turn it on, possibly ‘Turn on your eSIM under Mobile Network’), reboot your phone.
09-20-2023 02:04 PM
Did you turn the esim on to be the active service?
09-20-2023 02:02 PM
@Viking99 Use this direct link to support to fix
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-20-2023 02:00 PM
Neither working
09-20-2023 02:00 PM
Yes tried and nothing worked
09-20-2023 01:31 PM
Calls and real sms texts working? In and out?
09-20-2023 01:30 PM
@Viking99 Have you rebooted the phone or tried resetting network settings ? If still no luck please submit ticket with support to help
