ESim installation failure
Ericfeng
Hi
I was unable to install the eSim via the PM app. I also tried scanning the QR code but it says to try later or contact carrier. Can anyone provide me guidance? TIA
@Ericfeng wrote:
how to redownload?
@Ericfeng
you can use the app to download and install the eSIM.  If fails, you will need to try using the QR code.
But sound like you tried both, so, open ticket with PM support is the way to go for now
Ericfeng
how to redownload?
hairbag1
@Ericfeng
snipped from PM Help files re: esim...
What should I do if the eSIM download fails?
If the eSIM installation fails, you have the option to retry the download up to three times. If the issue persists after three attempts, you will have the option to contact a Customer Support Agent for further assistance.
SourDude1234
Hi @Ericfeng
Contact customer support using the following link, they can help you redo it.
Make sure to monitor the envelope icon on the top right since that is where you will receive the response.
