ESIM to Physical SIM
J_SMT
I have E-SIM and now i want to order SIM card for the same number under same subscription.
is it as simple as ordering sim card and activating it ? or is it gonna be new subscription?
J_SMT
Hey @Chalupa_Batman
That is very helpful.  Thank you.
Meow
Just order new Physical SIM. NO need for new account. After receiving SIM follow instructions to transfer number.
If you have retail outlet selling physical SIMs in you area go buy there as receiving SIM from PM might take longer than expected (and sometime you do not get it at all - lost in the mail).
Chalupa_Batman
Hey @J_SMT
SUPER easy to do. Just don't buy it directly from PM as it takes 3 weeks or more.
To get a new SIM card the fastest routes are these.
https://www.publicmobile.ca/en/bc/pick-up-SIM - Find a local store in your area.
Amazon - Here you can get it cheaper and maybe a few days wait $4.99
Or find a Mobile Klinik near you. https://mobileklinik.ca/stores/
Then go here to change it.
https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
