EMAIL ADDRESS
karaoke_mike
I joined Community. I was successful in changing my email address there. But, how do I change the email associated with my account. Did it automatically change too, or do I need to do something else?
Moody25
when I try to contact agent it says the following that
Correct the highlighted errors and try again.
  • Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and send the message when you are satisfied.
Meow
Only agent can update/change your email on PM account.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
@karaoke_mike   For My Account, you cannot do it yourself.
You have to open ticket with PM Support and have them to change for you
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
