06-25-2025 01:33 PM
Sick of this crap. E sim keeps locking every time I reboot my phone.
Anyone else?
06-25-2025 02:26 PM
its working now thanks
06-25-2025 02:14 PM
I have the correct code now, but it isn't even asking for the code now
It just shows SOS
06-25-2025 02:07 PM
hi @rossd
what is the exact error? i think it is a esim unlock code it is asking, it is not eversafe
you can try to buy a new esim to get rid of that problem. If you have trouble getting 2FA for login the app, click Didn't receive code and use email to receive
06-25-2025 01:37 PM
is just comes up as ESIM is locked. I give it the eversafe code, it asks to change it but wont accept the change.
says its wrong, It is an iphone
06-25-2025 01:36 PM
@rossd is that a sim PIN it is asking for? you can disable the sim pin.
what phone you have? iPhone or Android?
