E-Sim
MeganJudith
Hi. I’m trying to get an esim with the current number I have. I need to talk to someone about how I can get that done?
MeganJudith
Thank you so much !!
HI @MeganJudith
no new number or no new plan need.  You can put your current phone number and account on the new esim.
Just download the PM app and buy esim there as said above
MeganJudith
Hi. Thank you for your reply. Would I be able to transfer my current number and phone plan over to the esim ? Or will I have to get a new number and plan ?
HI @MeganJudith
no need to talk to anyone, you can do it yuourself
on the phone you want to install the eSIM, download Public Mobile app, then login, go to Subscription & Addon, then click Shop Sim card (at the bottom of the page) and you can buy esim there.  The process will guide you via installing the esim as well
But myself, I would avoid eSIM.  you cannot just transfer esim if you switch phone, you need to buy a new eSIM.  So, physical sim has no such problem
