05-29-2019 03:26 PM - edited 01-05-2022 05:08 AM
I have noticed that every time now I am on a phone call for over half an hour or less the call will drop and I am disconnected.
what is going on as I am within service. It is not an account or SIM card/ battery issue.
05-29-2019 07:43 PM - edited 05-29-2019 07:45 PM
@SelT can you try to power off your phone, remove the SIM card, let it sit for a minute or two, then reinsert the SIM card and power it back on. If still have problem,please sent Pm to MOD.
05-29-2019 04:30 PM
@SelT I had the same problem yesterday. It seemed like a friendly reminder for I had stayed on the line too long. It was time to stop talking....
05-29-2019 03:31 PM
There was a systemic issue with dropped calls a couple of weeks ago. According to PM, they fixed the problem.
You may need to contact moderator to check your account at the backend.
Send a private message to moderator through the following link :
