02-22-2021 12:11 PM - edited 01-06-2022 02:09 AM
Has anyone had any issues over the past few days regarding failed outbound text messages?
It has happened to me twice over the past two day. My phone errors stating message failed to send. After retrying, it does go through.
Regards,
02-22-2021 12:35 PM
thanks, I will give that try.
02-22-2021 12:32 PM
No, that is not the situation. I am in the center of town. Neve had issues before with any other carrier, of Public for that matter.
Thanks
02-22-2021 12:14 PM
@RobEh No problems here. Try this:
This procedure will force the update of the message centre number. You can verify it in your message settings.
02-22-2021 12:13 PM
@RobEh wrote:Has anyone had any issues over the past few days regarding failed outbound text messages?
Regards,
If you're in a fringe area with weak cell signal...that could be the problem.
