Dra not working
Chancewood21
Why is my internet not working my data
Staliger
@Chancewood21 more info would be helpful. Did it work before? Did you check your self-service account? Is there any data information written there? Maybe you used all your data.
geopublic
@Chancewood21  Check your APN settings.
@Chancewood21
What's the make and model of your phone? Can you send and recieve MMS (picture texts)?
Triguy
Log into your account and if no data is remaining then you have used it up.  You can purchase a 1GB for $15.  If there is an amount then check your APN settings.
https://productioncommunity.publicmobile.ca/t5/Getting-Started/how-do-you-know-if-APN-settings-is-co...
Also try rebooting your phone.
