02-20-2024
05:06 PM
02-20-2024
06:28 PM
computergeek541
Hi
I'm trying to download my usage data from Jan 1 to present, just for calls. I used the filters to select the dates and "unclicked" data I did not want.
I try clicking on "download" and nothing happens. What am I doing wrong?
thanks
02-20-2024 05:56 PM
I am using Chrome - thanks for checking
02-20-2024 05:52 PM
@Jopiary what browser are you using?? could be related. I had problem using Edge the other day but using Chrome works
02-20-2024 05:28 PM
Thanks for responding. No matter what I do, absollutely nothing happens when I click download! I'll try it on another computer - sounds like the issue might be in my computer.
02-20-2024 05:25 PM
@Jopiary the download usage will give you everything. Please download it first, the. use Excel filter function to filter out what you don't eant
02-20-2024 05:15 PM - edited 02-20-2024 05:21 PM
Use clean browser; use computer. It works as expected... Just tried...
But I would NOT trust PM usage report as I did NOT use any data on 15. feb and I did NOT call my vmail:
as I NEVER check my vmail calling from mobile. And yes, my minutes were not used in feb 2024.
So report is incorrect and I do check it ONLY when I have to help somebody else like yourself.
